3 inch Truxxx Leveling kit and 35s?
Old Aug 18, 2007 | 05:20 PM
fright88's Avatar
Ok so I am looking at putting bigger tires on my 05 F150 but I want to lift it as little as possible because of entry issues. And it is easier to load the chair into a lower truck. Anyways I called a local shop and they are pointint me to the following leveling kit
http://truxxx.com/ford_products/105020.htm
their website says I should be able to run 315 70 R 17 on stock offset wheels. Anyone know if this will work? Thanks for any help
Old Aug 18, 2007 | 05:30 PM
FoMoCoFan17's Avatar
Search ebay for a 2" Autospring spacer if you want an 1" less lift and still run 35's.
Old Aug 18, 2007 | 05:37 PM
BullRing's Avatar
ya go with the 2" level kit
Old Aug 19, 2007 | 05:16 PM
fright88's Avatar
Does anyone have any pics of the 2 inch leveling kit with 35s? Will I have rubbing issues with only the 2 inch? Thanks
Old Aug 19, 2007 | 09:26 PM
dbhost's Avatar
Take a look at this older thread.
https://www.f150online.com/forums/sh...g+Kit+with+35s
This topic gets covered a LOT... Generally speaking...
35x12.50s WILL fit with a 2 - 2.5" leveling kit on stock wheels and some aftermarket rims as well. Backspacing is critical, as is the size of the lugs on the sides of the tires. With most tires it's fine, but Mud Grapplers, TSLs, and other tires with extremely wide lugs, you will tend to rub a little on the control arms at full lock.
With wider rims, you will need to do some trimming of the inner fender liner, and valance, both plastic pieces, to keep from rubbing. Go no wider than 9" rim with this setup though.
