2004 Power Rear Sliding Windo
Old Aug 17, 2007 | 07:25 PM
medtech1925's Avatar
Does anyone know where the location of the switch for a rear power sliding window and if the factory wiring is there from the fuse box to switch location? I have installed a Ford rear power slider in place of the solid glass. All the factory wiring was there from the fuse box to motor location. Just need help on the other end.
Old Aug 17, 2007 | 07:30 PM
ONE04FX4's Avatar
Talking
my switch is in the small roof console. not sure if the wiring is already there on models not equipped with it.
Old Aug 17, 2007 | 07:46 PM
countyboy04's Avatar
If you have a moonroof then the switch would located next to it.
Old Aug 17, 2007 | 08:40 PM
XLTeaser's Avatar
I installed the whole kit, which included the wiring. On my 06, none of the wiring was preinstalled. Mounted the switch in the overhead console, between the map lights.
Old Aug 22, 2007 | 12:18 PM
Daneo2's Avatar
Has anyone had a problem with the sliding window failing? I thought my switch was bad and just paid $48 at the dealership and can't return it. I figured it was the switch since I had to press and jiggle it to work and now it no longer works. Now I need to get into pulling stuff out I suppose.
Old Dec 3, 2008 | 01:23 PM
fordsdad's Avatar
The wiring came in a kit from Ford, or you had to buy separate?
Can you provide Ford part numbers?
Old Dec 3, 2008 | 01:26 PM
azmidget91's Avatar
the rear window needs to be used offten to keep it lubed up and freely moving
