Umm should I worry ??? -after sparks changed-
Old Aug 11, 2007 | 05:22 PM
YOMAN's Avatar
Approx 1.5 week ago i changed the spark plugs with correct TSB part # for sparks. I followed the TSB direction, I used PB bottle spray and i used VERY LITTLE i say 1-1.5 sec spray each of sparks. It went smooth.
I did read some of here said to be expect some white smoke out after PB or whatever guys put it in to loose up sparks.
I was not really pay attention to rear end after start up motor also have private glass rear window. Today my wife said she see some puff white smoke came out then few seconds later its all clear fumes.
No engine light, nothing funny sounds, its all normal running engine.
After i started up again, wife said its much less puff white and i ran to rear and i could smell a little bit of PB/gas..
I guess it will take time for PB to wear off from engine ?
Should I worry ??
Any tips or advice will be great...
God.. i hope its normal
Thanks!
YOMAN!
2004 Screw FX4
Old Aug 11, 2007 | 08:59 PM
risupercrewman's Avatar
You should be just fine.......... At that mileage did you change out the plugs?..........
Old Aug 11, 2007 | 10:12 PM
YOMAN's Avatar
I changed sparks at 40k with no problem.
I pulled sparks at 15k to inspected, cleaned it then put it in which is help to less headache with sparks issue so I'm happy that I did since at 40k 8 spakrs came out ok. Whew.
Yoman
