Edge Q's
Old Aug 9, 2007 | 10:12 AM
extremeethan's Avatar
Edge Q's
My edge on Level 3 get a bad tranmission clunk, ill let off then get back on ans it will clunk, also if I go from regular driving to punching it to pass someone it will down shift with a bad clunk. If I drive in level 2 all my tranmission clunk issues go away but then my intake drone is about 10 times worse and I loose a little over 1 mpg ( long time records prove this). My question is how can I get the power and fule milage of level 3 but the trans shift points and shift pattern of level 2?
Old Aug 9, 2007 | 10:15 AM
The torque converter can do some funny things on Level 3. That is possibly what you are feeling. What are your settings?
Old Aug 9, 2007 | 10:28 AM
Stock level 3 I know about the slight clunk as it locks up and unlocks I have that too but I get full on gear slam from light throttle to a lot like slowing around a cornor then taking off
Old Aug 9, 2007 | 10:38 AM
I would change the settings and see if it has any affect. I would go with:
Shift pressure: 1-2=+12 2-3=+12 3-4=+9
WOT shifts: 1-2= 5250 2-3= 5250 3-4= 4800
if running 93 octane, bump timing +1
Max speed: 110
Max rpm: 5650
WOT fuel: +1.5
leave normal shift alone
Set idle rpms to 800
I would try something like that and see what happens.
I have been running those settings for over a year splitting time about equally for level 2 and level 3. About 22,000 miles with no trouble.
Old Aug 9, 2007 | 10:50 AM
i worry about tweaking the edge +12 seems like a lot. I dont know about tuning cars and messing with stuff I dont know worries me.
Old Aug 9, 2007 | 10:55 AM
A guy I work with has had his at +16 for over a year. I like the firmness of +12 and not as harsh. It will not hurt it, but try something lower, say +6 or +9 just to see if it makes a difference. If it doesn't go back to the defaults setting.
