Cheap Mod?
Cheap Mods?
Forgive me but it has been a little over a month since my last mod and now the bug's biting me again, but money has been tight lately. What are some cheap mods you've done or have heard of?
I know this is stupid, but I HATE plastic valve caps...
Get a set of good Chrome valve caps... It is a very minor thing, but especially with Chrome, or polished wheels, it makes the valve stem stand out a WHOLE LOT LESS...
Bugflector was under $40.00
Check to see if there is a Radio Shack near you... Micro CB and a mag mount antenna should run you around $50.00 if you shop it right...
but another cheap mod is if ur still have ur stock air intake than remove the silencer... its inside the L shaped tube... its bout the same as havin a cai... i did it and i could most def tell a diff in throttle respones!! if u want more info just let me know
Originally Posted by BIGDAVE128
the thing is with those chrome valve caps it can crack ur valve stem... a buddy of mine was the same way and put chrome caps on and ended up having 3 different stems crack....
Also he has the 5.4L motor so that wouldn't quite work.
Yeah, pulling the baffles does not apply to the 5.4L.
You can swap your stock filter element for a K&N as well. Not as big of an improvement as a CAI, but an improvement.
The bugflector, ventvisors are good ideas too. Another one is DIY window tint. These windows aren't very dark stock...
A mod that will only cost you about $0.40 or even less if you have the materials is the fog light/high beam mod, where your high beam headlights and fog lights will be on at the same time.
For about $25 you could buy some VHT niteshades and clear coat and tint your third brake light.
You could upgrade you headlights or fogs to silverstars for about $40/pair.
Thats about all the stuff that I can think of for under $50.
Change out the map and interior lights to LEDS or get some Catch-All Floor Mats front and rear.
http://www.autoanything.com/generic_...0723&p_id=1455
Just got back from Pep Boys and got the EZ Down from DEE ZEE for $38.00. There internet site says $65 and the sticker on the package says $49.99 but it rang up for $38 + tax. So its even cheaper then e-bay.
