CB Antenna Mount... In Bed
Hey, I was wondering, does anyone make a mount that goes in place of the in bed tie downs?
I'm thinking that it might be an ideal place to mount my CB Antenna. Thanks!
Check out http://www.walcottcb.com/index.php
They have a few options for mounting in the stake hole pocket otherwise I don't know any that are specifically made for that spot.
This issue is being handled in another current thread...
https://www.f150online.com/forums/sh...d.php?t=293846
BTW, Sorry about the short reply. But I was short on time when I originally posted this...
The antenna mount you chose will be dependent upon the specific antenna you chose. If you are going with a FireStik or something small like that, the stake pocket mounts are fine. If you are using a serious antenna like a Predator 10K, or a 102" SS Whip, then you will need a stouter mount to handle the stresses.
That Boss-Hawg mount would handle it, but that appears to be the ONLY no drill mount I have seen that is going to handle a decent sized antenna.
