Windows Won't Roll Up
Old Jul 15, 2007 | 03:13 PM
MeanGene's Avatar
Today I got into my 2004 SC and while driving down the road the rear drivres side window just started going down little by little. By the time I pulled over it was all the way down and it will not go back up. I think this is the broken cable problem? I will be taking it into the dealer on Monday. Is there anything I should request to fix this. Are there updated parts that can be replaced in each window so that it dosen't happen again?
Old Jul 15, 2007 | 03:44 PM
Oxlander's Avatar
It sounds like the classic regulator failure than has become common place with the new F150. I don't believe that the regulator design has been updated which means the replacement parts may be prone to the exact same failure as the OEM.
I have had both of my front windows do this on me and I replaced the regulators myself. With the old ones out I compared them side-by-side with the replacements and I could not detect any differences. Good luck with getting this problem fixed.
