What PSI should I run in my tires? (TerraGrappler 325/60R18)
I feel dumb asking this question, but here goes....
I've had a set of 33" Nitto Terra Grapplers (325-60R18) for almost three years now (love 'em by the way) and they've just started to make some addt'l road noise (around 50K miles on them).
It got me thinking that maybe my tire pressure was off.
I do 99.9999% highway/on-road driving. What psi should I be running these tires at ideally? And is the tire noise common toward the end of this tire's life?
Thanks...
Thanks...
Originally Posted by Adam06FX4
depends what rims you are running them on. thats a pretty wide tire for a factory rim so id tend to run them around 35 to keep them from wearing in the center.
On vehicles with a TPMS system and load range D tires, the low pressure to set the warning off is 38.
In my 295/70/17 Nitto TG's I am running 50psi. The handling feels real mushy down around 40psi. I've been running this pressure for about a year now and I haven't noticed any uneven wear even though they are mounted on factory 7.5" rims.
Thanks for the replies.
I'm actually running these tires on Eagle 178s (18x9). I've had them at 40psi for the last year or so, but I think I'll bump that up to 45 or so and see if there's a difference.
I have mine at 45 all the way around, most of the time. If I know that I am going to be hauling anything heavy (over 1000lbs) or towing heavy, then I pump them up to the max.
I have mine mounted on 18X9's also.
