Antenna
Old Jul 10, 2007 | 06:23 PM
hutch5.4's Avatar
Antenna
Is it removable ? I'm wanting to put a smaller one on so i dont hit the top of the garage with it each time i drive in.
Old Jul 10, 2007 | 06:34 PM
KSpencer's Avatar
Yes, it just unscrews out of the base (easy). There are two ways to go here. First, just cut the whip antenna down to your needed size and epoxy the ball back on the end (lots of people have done this). Second, just buy an aftermarket one (which I did). There are lots to choose from with varying lengths, colors, and finishes. Good Luck.
Old Jul 10, 2007 | 06:40 PM
hutch5.4's Avatar
yeah thats the problem i can't get a firm grip and turn it. Thats why i was asking because it wouldn't budge
Old Jul 10, 2007 | 06:48 PM
KSpencer's Avatar
I used a piece of rubber tubing just large enough (ID) to go over the antenna at the base, then used a pair of pliers to turn it out. This allows you to get a better grip without damaging the finish. Another thing I had to do with my aftermarket antenna was place a lock washer (stainless) in between to keep it from backing out while driving. The original whip antenna's threads were fairly tight in the base, and the aftermarket was not as tight (leading to backing out). Good Luck.
Old Jul 10, 2007 | 06:49 PM
mlawdawg's Avatar
put a towel over the base and gently use some pliers.
Old Jul 10, 2007 | 07:37 PM
hutch5.4's Avatar
Already tried that it just slides.
Old Jul 10, 2007 | 09:52 PM
Impact9's Avatar
time to get medevil on that sucker!
