Help with my 04 - Gas Peddle squeaks
Old Jun 29, 2007 | 05:26 PM
fordworker's Avatar
I am hoping someone can give me a clue. My gas peddle squeaks when I give her gas - worse when its cold outside. It works, but the noise is annoying. Any ideas? Thanks in advance.
Old Jun 29, 2007 | 05:45 PM
wrench007's Avatar
You might try some wd-40 or similar lubricant and spray where the throttle pivots at the control module. Other than that there isn't much else that could cause the noise unless it's inside the control itself. In which case you may need to replace it. No cables to worry about.
Old Jun 29, 2007 | 06:19 PM
Jolly_Green_Giant's Avatar
Had that problem at about 26,000 miels. little spray lube did the trick.
Old Jun 29, 2007 | 07:31 PM
Grubrunner's Avatar
WD-40 will solve your problem.
