Endless 3rd Brake Light Leak
Old Jun 27, 2007 | 05:48 PM
F150 Duke's Avatar
Hey Guys,
Well I'm about to give up.
I have an endless 3rd brake light water leak. I did the bubbles in water idea to identify where it was coming from. Then I put on a new foam gasket on the 3rd brake light and then put silicone selant around the edges of the 3rd brake light and then in the screw holes because they had some air blowing out too.
Is the silicone selant not the right stuff to use? Is that why it's still leaking?
It's a major pain and I want to be done with it. I appreciate any help or advice you guys have.
If it means having to pull the brake light again, I'll also need advice on how to get the silicone out of the screw holes that I already put in there.
Thanks,
Duke
Old Jun 27, 2007 | 06:11 PM
Screw-Me-05's Avatar
If you have an 05 isnt it under warranty? let them drop the headliner and put some sort of silicone or stopleak in there. thats crazy that it still leaks after all that silicone
Old Jun 27, 2007 | 06:29 PM
F150 Duke's Avatar
Well, it's complicated. It's an 05, but I'm over 36,000 miles already and it's a aftermarket LED 3rd brake light with my XM and Navigation cords running out of it.
Duke
Old Jun 27, 2007 | 06:54 PM
scorpio333's Avatar
Dunno about the silicone, after redoing the bathtub 8 bazillion times I like to avoid it. I used some storm door sealer from Home Depot when I switched mine out. Peeled the sticky side off and stuck it to the truck then tightened it down real good. Swapped the light again and never a drop.
