Wow I have a bunch of mod Qs
Old Jun 27, 2007 | 04:18 PM
bronkx1's Avatar
First...2005 STX supercab 4x4 9000 miles.......I did a bumper swap and added 06 bumper and factory fogs.I mounted 285/70/17 toyo open ATs on stock wheels.2" autospring lev kit up front.Alpine w200 in the dash with sirius and video bypass.
The questions....
The 06 bumper I added has no grill for the center?My stx bumper did have a grill.Is this normal?Can a grill be added as I did not see any mounting points.
Rear lift? My rear springs lost about 1 1/2 inch of height.I went to the dealer but as they always do to me no problem found.They have lost height as the autospring was put on at 2,000 miles and we measured the truck to see where the ride height ended up.I have looked around for new lift springs but I have not had much luck.I called deaver{sp} about springs but they wanted me to send in old springs.How can I get 2 inch of lift in the rear?Longer shackles?blocks?
My supercab has manual windows and I did take the back doors apart and they do have manual regs in them they are NOT solid mounted.I did a search and looked thru a ton of posts about adding power windows.My question is with factory power regs do they come with motors or is a sep part?Any one have part numbers for the 4 doors in a super cab?I plan to have 1 switch run both back doors and sep switch for each front.
Inst cluster.I also did a search on a cluster swap and it seems the swap is easy but getting the cluster programed is the problem.How are people dealing with this problem.I did a look around my area and was not able to find any speedo shops any place.And my 3 local dealers suck and hard.
If any one can offer some tips or help I would be thankful.
Old Jun 27, 2007 | 04:29 PM
mSaLL150's Avatar
put on an AAL (add-a-leaf) in the rear. i think skyjacker and superlift make them. will lift your rear 1.5-2 inches usually. will cost you like 150-200 bucks.
Old Jun 27, 2007 | 04:34 PM
mSaLL150's Avatar
here you go
http://www.autoanything.com/suspensi...A2637A0A0.aspx
