Vehicle Shimmy
Old Jun 27, 2007 | 02:04 PM
swhite005's Avatar
Vehicle Shimmy
During acceleration between 40mph and 60mph, the vehicle shakes. When throttle is released, shaking stops. Acceleration above 60mph, no shake. Tires and wheels are balanced. What else could be causing this?
Old Jun 27, 2007 | 04:05 PM
faawrenchbndr's Avatar
Has it been raised or lowered? Sounds like u-joint.
Old Jun 27, 2007 | 04:20 PM
wrench007's Avatar
Like faawrenchbndr said, maybe u-joints or a drive shaft problem, Chock the vehicle, put in neutral and push up and down on drive shaft to see if there is any movement, also comes to mind is engine mounts or the transmission mount may be loose. But it does sound like a drive train problem. Please remember I said CHOCK the vehicle before getting under in neutral. If it's u-joints you should probably notice vibration under de-acceleration also.
Old Jun 27, 2007 | 11:04 PM
guitarman502's Avatar
I have the same problem.... ive been trying to figure out what it is.... hopefully one of us finds something out and can alert the other
Old Jun 28, 2007 | 02:40 AM
Grubrunner's Avatar
Are you runing OR tires?
