New problem 2, on 04 crew
Has anyone had to slam there doors with there Lariat to get the "Door light" on the dash to go out ? And sometimes with the key out the radio will stay on when I open the door. Still working on getting to A/C fixed at the dealer.
It's your drivers door switch that has dirty contacts. This is a common Ford problem. Spraying the switch with wd40 should fix the problem, for a while. The switch should be located in the door latch mechanism, or at least it was on the previous bodystyle. Spray liberally and you should see both problems go away.
