Can a factory sub be hooked up to a regular 6 disc changer?
Can a factory sub be hooked up to a regular 6 disc changer? What work is involved?
Let me know. Thanks |
Anyone know?
Thanks |
It can be done, but I'm almost certain that the non audiophile radios do not low frequency output signals that are required for the subwoofer.
You would have to buy a low pass filter and splice it into your rear speaker wires. They sell these at pretty much all mobile audio stores for about $20-40 or so. This is where the amp would get it's signals for the sound that would come out of the sub. Of course you would have to also supply power, ground, and remote power to the amp as well. Personally I don't think it's worth the hassle. |
Isn't the six disc changer an audiophile unit?
Thanks |
Anyone know if this will work?
they actually make two different versions of the six disc changer one is an audiophile and one isn't the way to tell is if it has two or three plugs on the back not including the antenna. As far as hooking up a factory sub to a non audiophile I am sure it can be done, but it will require a lot of splicing and probably won't sound as good because of the crossovers that are built into the audiophile. My advice would be to look for an audiophile deck on ebay or the classifieds, or just buy an aftermarket deck with more options i.e. ipod hook up and sat hookup.
Is there any other way to tell if I have an audiophile besides pulling out the head unit?
Thanks |
Thanks |
it's easy. All you have to do is buy a line level converter that splices into the harness. Like this.
http://www.crutchfield.com/S-TIwVutP...g=721&I=101PL2 Your head unit doesn't need to be audiophile. The audiophile has the factory sub harness but the harness probably just carries signal and the sub filters out the high frequencies using a built-in crossover. The line level converter above splices into the harness to pick up signal and changes it over to R&L RCA lines. Run the RCA's to an amp and hook up your sub. Use the low pass crossover to filter out the levels above whatever frequency your sub can handle. If you have an amp that can accept line level inputs, you just splice in and run the wires to the amp. It took me longer to figure out how to mount the amp than it did to wire it all up. |
To the original poster, that inline converter in the link BMS posted is exactly what you need in addition to an amplifier, factory or aftermarket, and sub. |
