Dome & Map Light Mod
Old Oct 12, 2007 | 01:50 PM
Jditta's Avatar
[QUOTE=DTheobald]
Originally Posted by pmason718
license plate 194
dome is festoon 42mm
and map lights and top brake lights are 921
yes dome rear, map front
Your like a light part # guru
Old Oct 12, 2007 | 01:56 PM
pmason718's Avatar
[QUOTE=DTheobald]
license plate 194
What happens to the housing that surronds my factory license plate bulbs. Will this still be intact and the bulb just replaces the factory bulb there now? Also who should I order from. v-leds or superbright what eva its called.
Old Oct 12, 2007 | 03:04 PM
pmason718's Avatar
Ok I have everything ready to order but im stuck on the License Plate bulbs. Do I just replace my factory bulbs with the 921 LED or do I replace it with one of the WLED off of their site. Check the link below. Also what happens to the housing surrounding my license plate bulb
http://www.superbrightleds.com/mini-wedge.html
Old Oct 12, 2007 | 03:54 PM
pmason718's Avatar
Never mind fella's. I spoke to a guy on the phone and this is what I ordered.
Map Lights WLED-WHP (2)
When you make your dome light purcahse make sure that you select your bulb type to 42mm if you decide to go with this product.
Dome Lights 42mm 4210-WHPX 3 LEDS (2)
They are called High Powered LED Festoon Bulb
License Plate Lights WLED-WHP (2)
3rd Brake Light, Lights 921-x12 Wedge
Total: 52.60
Old Oct 12, 2007 | 04:05 PM
BigBlackFX4's Avatar
Total: 52.60
Thanks pmason,
I've been thinking about doing this too. Please post a review and pics after the install.
Old Oct 12, 2007 | 08:45 PM
pmason718's Avatar
I will post a review. How can I post pics directly to the site like the pic of your truck you have
Old Oct 13, 2007 | 07:15 AM
Go to your User CP and create a signature, then in your sig, post a link to a pic in your photo gallery.
Old Oct 13, 2007 | 10:39 AM
1sweetsvt's Avatar
dont get led's for your dome lights, they wont work too well. it'll throw off a cool white/blue color but the housings arent made for leds so they wont reflect the light like they're supposed to. led's do work wonders in 3rd brakes lights tho
Old Oct 30, 2007 | 10:08 PM
pmason718's Avatar
How do I remove the dome and map light housing, so that I can replace the bulbs with LEDS
Old Oct 30, 2007 | 10:10 PM
ThumperMX113's Avatar
Depending on the one you have in the rear, the one I've got I just pulled hard and it came down. The front one you have to open up the sunglass holder and pull or something. I can't really remember.
Old Oct 30, 2007 | 10:21 PM
wdhigh's Avatar
anyone switched interior lights to red?
Old Oct 30, 2007 | 11:04 PM
LovetheTide's Avatar
For the fronts....
Open the sunglass compartment and put both hand on either side like soo...
Then pull like a ****.
Old Oct 30, 2007 | 11:52 PM
pmason718's Avatar
I have the 07 not sure if it makes a difference but I have the stupid rail system and my sunglass compartment is easy to remove but its doesnt have anything to do with my map or dome lights. Once this compartmen is removed the map lights are still there in their own housing.
Old Oct 31, 2007 | 12:20 AM
05'ThumpinSTX's Avatar
This doesnt have anything to do with the lights but Josiah- where did u get your F150 emblems for the front and back of your truck. I totally need to get a pair of those!
Old Oct 31, 2007 | 09:34 AM
pmason718's Avatar
Probably http://www.patriotdecals.com/. This is where I got mine from
