Can I switch instrument clusters???
Have an '05 f150 xl and would like to switch instrument cluster to one from say an xlt. Anyone know if this can be done without any real problems? Was just wondering if optional gauge plugs are in dash already.Any takers?
Originally Posted by scorpio333
It sure can be done, if you have the patience to read up and a couple bucks to put towards it. There's a few threads with great detail, search for 'cluster swap' or 'lariat cluster'.
I've put a FX4 in my XLT and haven't had any issues. The plugs are the easy part. The Lariat cluster is a little different with the message center additions (if you want to add those, I think it'll work without them), but XL to XLT to FX4 should be no issue plug wise. At a high level the issues are mileage programming and dealers programming the 'as-built' data to the new cluster.
Thanks again!!
Originally Posted by mitch150
Have an '05 f150 xl and would like to switch instrument cluster to one from say an xlt. Anyone know if this can be done without any real problems? Was just wondering if optional gauge plugs are in dash already.Any takers?so, when I picked up my truck, it had about 400 fewer miles than when I dropped it off. Hopefully someone knows how to program the ODO because it sounds like the dealer does not have the ability to do that. I obviously was not happy about this - poor design. the ODO should be stored in non-volatile memory somewhere along with trip odometer - that was reset to zero and tends to get reset whenever the power goes out.
Hope you read this scorp
Yes it should be. And yours DOES have a tach, hold down the trip reset button while starting the truck and you can scroll through different screens like volts, fuel pressure, tach, mph, etc..
As far as I know all the F150 clusters have two of the exact same harnesses that plug in on top. However, there's been a few that have upgraded the XL and STX clusters to the XLT/FX/Lariat cluster and I've not read anyone having any tach issues. To the best of my knowledge (someone correct me if I'm worng)I believe the tach reading comes out of the PCM and straight to the cluster, if no tach is present that signal is ignored. With that said, the PCM may need to programmed with the correct data before the tach operates correctly, but it should function since you can view a tach reading in your message center (If I recall, hold the trip button in while starting?).
You get a new cluster yet?
Thaks for the info!
Sorry for the delay in response
Is the dealership the only place where you can get the cluster? Does anyone know what a dealership will Typically charge for labor and parts? I don't have the outside temp on my cluster. Will the new cluster support that function? thanks
