Popping while turning?
Old May 21, 2007 | 06:25 PM
04procompLARIAT's Avatar
Everytime I turn into my driveway I hear a pop coming from my suspension. I figured it was my sway bar so I tighted it up. Still popping! Any ideas?
Old May 21, 2007 | 06:42 PM
extremeethan's Avatar
I would guess a ball joint or double check the top mount for the coilover is tight as well as the steering link. Also is it from the front or back. If you really cant tell Jack up the rear to seperate the leafs and give each slider a blast of WD. My poping was from the crap gunked up between the leafs. If still not that check the N2 in the coilovers, 200 PSI
Old May 21, 2007 | 07:07 PM
K1NGoftheRanch's Avatar
balljoints x2
Old May 21, 2007 | 07:26 PM
OH forgot to mention...My upper balljoints are uniballs. Could it be the bottom balljoint?
Old May 21, 2007 | 07:29 PM
bferrel's Avatar
I have a popping too, let me know if ya figure it out.
Old May 21, 2007 | 08:40 PM
Thats what I ment lower
Old May 22, 2007 | 04:00 PM
Ah crud...I should have dropped my truck instead of lifting it!
Old May 22, 2007 | 05:06 PM
dbhost's Avatar
If your truck is 4x4, it COULD be CV joint...
Old May 22, 2007 | 05:10 PM
Not a 4X4.
Old May 22, 2007 | 05:32 PM
I ment lower ball joint. Did any of these work for you?
Old May 22, 2007 | 05:42 PM
i havent had the chance to check my lower balljoint yet...
Old May 24, 2007 | 07:18 AM
jr105's Avatar
I just fixed my pop yesterday. It would pop when I turned while braking, but not all the time. I couldn't tell for sure if it was coming from the front or back so I tried the WD trick that extremeethan mentioned. When I did the leaves nothing happened so I sprayed the shackles and the popping got worse. I found the 2 lower bolts on the rear shackle had loosened. I tightened them both about 2 turns and no more pop.
