Clutch Question
Old May 21, 2007 | 11:39 AM
BtownFord's Avatar
Clutch Question
This is in the wrong forum I know but everyone here is extremely knowledgable so I Figured i'd give it a run. I Just picked up a small pickup truck for my daily driver yesterday. It is a 5 speed with 2.2L 4Cyl. Sometimes when I go to crank I have to pump the clutch to the floor and back up to make it start.
In other words:
If i depress the clutch and it doesn't start, I then release it and push it back down and it starts.
I know nothing about clutches as this is the first 5-speed i've owned. Is this a loose wire in the starter or a bad connection? Or something else?
Old May 21, 2007 | 12:25 PM
nuclearthreat54's Avatar
In other words:
Idk but you should of posted this in GD. A lot more people and it would deffintly belong in there. This will be moved pretty shortly
Old May 21, 2007 | 12:26 PM
BtownFord's Avatar
Edit
Old May 21, 2007 | 01:24 PM
02SuperCrew4X's Avatar
I can almost guarantee that its the clutch start switch in the S-10 you're driving (or one of it's variants).
Old May 21, 2007 | 02:16 PM
BtownFord's Avatar
I was thinking something along those lines. Do you know how difficult it is to install another one?
Old May 21, 2007 | 02:57 PM
Jolly_Green_Giant's Avatar
Believe he stated that he knew that...
Old May 21, 2007 | 09:30 PM
BtownFord's Avatar
Update: Just replaced the clutch start switch. Picked it up from NAPA for like 30 bucks. Still has the same problem. Won't start but with a pump of the clutch once or twice it will start
Old May 21, 2007 | 10:09 PM
That doesnt make it right to post it here. Just because you are aware you are shooting the president, does not make it ok to shoot him. Unless its Bush
