Pro Comp Install Questions
Old May 17, 2007 | 06:28 PM
kalebarellano's Avatar
How can I remove the piece that connects the sway bar to the LCA? It spins when I turn it so it cannot be loosened.
Also could I leave the bottom of the shock connected to the LCA, then just disconnect the LCA from the frame, and install the spacer with it connected to the LCA?
Old May 17, 2007 | 08:41 PM
extremeethan's Avatar
Key to ball joints is to use wrenches. the lower part of the ball joint shaft is ment for a small wrench and then get the right sized wrench for the nut. hold the ball joint and twist the nut off. if that doesnt work find a way to pry the sway bar link down into the control are more and then get the nut off. and for the shock you can do it that way but it might be more work then its worth but it will work.
