Different Shocks for the SuperCrew
I had posted this in the suspension area, but since that area is used more for lifting/lowering there were no responces.
I have been looking at replacement shocks for my 2WD 2004 Supercrew. I have found some stores that use different Bilstein part numbers for the SuperCrew model.
Most places will sell Bilstein HD's all around for all 2WD 2004 and up models and use the part numbers: BE5-A761-H0 (HD Front) and BE5-A762-H0 (HD Rear).
Other stores have the same part numbers for the same model year except they use a different part number up front for the SuperCrew only. Using the part numbers: BE5-A761-H1 (SP Front) and BE5-A762-H0 (HD Rear).
I know that HD = Heavy Duty, not sure what SP = ?
Does anyone have any experience with this type setup?
Any comments?
Also, it has been mentioned that the Bilstein shocks may not come with the front upper bushing. Is this true? If so, should I keep using the old or replace them, recommendations?
Any comments?
After making some phone calls I found out that the SP is the Sport model of the Bilstein Shock. I guess that on the larger F150 with the SuperCrew cab they run the Sport valving up front (more damping) and the Heavy Duty (less damping) in the back.
