NEED HELP ASAP edge
Old Apr 19, 2007 | 10:45 AM
Copeland!'s Avatar
NEED HELP ASAP edge
Looking at purchasing a used edge that was previously installed on a 5.4 V8. Could I purchase this edge and use it on my 4.6?
-TIA
Old Apr 19, 2007 | 10:53 AM
RamSS/T's Avatar
-TIA
Yes, as long as it has been returned to stock. In other words the original owner will have to reload the stock tune in his truck before you can use it to tune your truck.
Old Apr 19, 2007 | 01:00 PM
Copeland!'s Avatar
GREAT, thank you. Waiting to hear back from seller on payment instructions.
I am pretty excited although a bit nervous doing this to a truck with 4k miles though
Old Apr 19, 2007 | 01:02 PM
kd4crs's Avatar
I put my Edge on at 1,500 miles and it has been great ever since. You better call Edge to see if they support your PCM version, though since you have an 07.
Old Apr 19, 2007 | 01:03 PM
beckerjs's Avatar
-TIA
Edge might not have the pcm code for your 07 truck yet. If you install the Edge without the right code you might get in trouble.
Old Apr 19, 2007 | 01:04 PM
Copeland!'s Avatar
What changed between 06 and 07 that the edge would no operate effectively?
Old Apr 19, 2007 | 01:10 PM
MGDfan's Avatar
Ford produces dozens of PCM code revisions every model year - in fact it has the most variations of all/most vehicles.
Tuners need to recognize & support each different PCM code, and further, the " strategy code" to work correctly or even safely. [A Single PCM code can have several differen strategy updates].
This work load explains why there may be a gap in support - until they have a chance to re-write for it.
Edge has chronically been behind in this regard.
Old Apr 19, 2007 | 01:12 PM
hmfic's Avatar
I've had my '07 for about 2 weeks now.. The hex code is "RXDG4B2.HEX".
I emailed Edge a few days ago and they said mine IS supported at this time. The reason I emailed them is that I was worried about the "2007 check engine light" problem that many members have had. Here's the response:
"I am showing that we do support that calibration... As for the check
engine light, we just finished our latest update to support those trucks
without throwing the light.... As for the unstable versions....those
are calibrations that may not be suported.... They are more a beta test
then anything....I hope this helps.
Thanks,
Aaron Chapman
EDGE PRODUCTS
888.360.3343 ext 129
fax 801.476.3348
1080s. Depot Dr.
Ogden Ut. 84404
Achapman@edgeproducts.com"
Old Apr 19, 2007 | 01:13 PM
Copeland!'s Avatar
Ugh, this is becoming a headache.
Well since the edge can be updated via USB, there is probably an 07 PCM update right?
Old Apr 19, 2007 | 01:23 PM
MGDfan's Avatar
Again - depends upon YOUR specific strategy - don't assume it's the same as for hmfic!!! Read what I posted before.
Do what he did; when you get your Edge - hook it up just to read your HEX code. Contact Edge & follow their lead. Ok?
Excellent advice, hmfic
Safer this way - don't play roulette.
Cheers
bubba
Old Apr 19, 2007 | 01:33 PM
beckerjs's Avatar
If they don't support it now they will soon enough, buy it, email Edge, use it when you can. Once you get used to it you won't want to be without it.
Old Apr 19, 2007 | 02:34 PM
Copeland!'s Avatar
Thanks guys!
Old Apr 19, 2007 | 06:13 PM
Just make sure it's the eef2400 and not the eef2100.
Old Apr 19, 2007 | 06:38 PM
chief40al's Avatar
Also get the Lightning Software that goes with it.
Old Apr 20, 2007 | 09:39 AM
Copeland!'s Avatar
Deal fell through
