Hualing mulch this weekend, got a ?
How much mulch do you think I can fit in the bed of my 05 STX flareside 4x4 4.6L, 3.73 limited slip, 6.5ft bed without the weight causing any problems with the handling.. Doing some yard work this weekend and my wife is wanting me to put some mulch down and I only want to make one trip. Thanks for the help.
Andrew
Andrew
Andrew
Andrew
Originally Posted by MGDfan
Pretty much all you can cram in there, as long as it's not dripping wet.
Been there and done that many times. So long as it's not soaked, you'll be fine.
My '97 would get a bit light in the front end but I hauled a load of pea gravel in my '05 and other than the squat, I never knew it was in there.
Plus mulch is pretty light compared to say dirt. I wouldn't worry about the driving charateristics unless you have to go 20-30 miles. For me it's just a 1.5 drive from the garden center to my house. I used to take a yard at a time in my 05 Tacoma with a whimpy little 4 cyl. It would ride on the bump stops from there to my house until is it's unloaded. Just drive carefully and you'll be fine.
Heck I even overloaded it with wood and let it sit overnight and it had no ill effects to the suspension. Just had to drive a little more cautiously as it made the truck have a "tail waggin" feeling.
you can put two full scoops of mulch if they are loading it with a tractor/backhoe bucket and it will sit the truck down a little but its fine, i have even hauled 2.5 ton pallets of limestore rocks and the truck run normal, basically its all in your instinct if you feel like it can then do it if not then take two trips, just air up the back tires before or right after you load it with weight.
Hi.
I just hauled a pallet of 16"x16" Sidewalk stones. 15lbs each, 70 stones total. That was 1050lbs total or a little over a half ton. The truck squatted pretty good and had a little rear sway going on. My truck is a 05 Lariat Scab 6.5' bed and 4x4. I had no problem with speed though. Still could run 55-60 without a problem. Braking was a little different.
Thanks for all the replys. I fell better about hauling it now. Was alittle worried since the last time I hauled mulch I was having trouble in the Sport Trac that I had. The guy loading it said that the bed should hold 2 yards. It held it, but I had a hard time driving. Rear bumper was close to the ground and every time I hit a bump, i clould hear my exhaust pipes scraping on the leaf springs.
I'll try it and see what happens. Thanks.
Andrew
Andrew
Andrew
Andrew
keep us posted
i just unloaded 2 weeks ago 2 full yards for garden mix soil from the greenhouse, i have a 2006 4x4 supercab, with tow package, she was squattin a little but didnt handle bad, i had about 4 miles to drive.. not bad though.
ive loaded my truck all the way to the top of the roof with firewood and never had a handeling problem or anything, hell i was suprised that i out accelerated my ex's dads 350 silverado because he was hauling the same amount of weight
I currently have 2 yds of cedar mulch that is pretty wet in the bed of my truck. The drop hitch ball is a bit low and hits now on some steep driveways. But other than that, it's fine.
