Doing oil change this weekend, what do you recommend?
Old Apr 5, 2007 | 08:00 PM
05F1FIDDY4x4's Avatar
Doing the first oil change on my truck this weekend. 11,500 miles. Bought it when it had 8,400 miles. Its an 05 4.6L. What type oil do you recommend using? Should I use reg oil, synthetic blend, or a full synthetic? This is my first V8 and am not sure on which is best to use. Also, What filter should I get? Thanks for the help.
Andrew
Old Apr 5, 2007 | 08:02 PM
runnerboy's Avatar
personally i would go with motorcraft oil and filter.
Old Apr 5, 2007 | 08:24 PM
F151's Avatar
So would I.....
Old Apr 5, 2007 | 08:28 PM
sterusmall's Avatar
Same here!
Jordan not Mike's Avatar
I recommend a Fumoto Valve.
http://www.fumotovalve.com/
Say goodbye to stripped threads and messes.
Old Apr 5, 2007 | 08:31 PM
Budha05STX's Avatar
Motorcraft filter for sure.
I've used both the Motorcraft (syn blend) oil (first few oil changes) and the Mobil 1 full syn since.
Old Apr 5, 2007 | 08:58 PM
RUSS04's Avatar
x2
Old Apr 5, 2007 | 09:07 PM
Hokieron's Avatar
X2. One of the best and easiest mods ever.
Old Apr 5, 2007 | 09:11 PM
FX4&EXCURSION's Avatar
Same here....Keep it factory.
Old Apr 5, 2007 | 10:21 PM
jjmIII's Avatar
Whats the MC filter part#?? Can I use the one I have left over from my 98 4.6?? I just bought an 05 5.4 also...
Old Apr 5, 2007 | 10:36 PM
Quintin's Avatar
F1AZ-6731-BD, Motorcraft # FL-820S. Yes, the same filter from your 4.6 works on your 5.4 3V.
Old Apr 5, 2007 | 10:43 PM
ktexas's Avatar
Motorcraft filter and Mobile 1 full synthetic is what I use. The motorcraft filter is the for sure thing to use. The oil is more personal preference.
Old Apr 5, 2007 | 10:50 PM
thetruck's Avatar
Mobil 1 oil and K&N oil filter.
Old Apr 5, 2007 | 11:07 PM
ThumperMX113's Avatar
I use Mobil1 and a Motorcraft filter.
Old Apr 5, 2007 | 11:15 PM
Grubrunner's Avatar
Same oil [5W-20] but Mobil 1 filter.
