AC: Alternating degrees of coldness
The past couple of weeks I've been running my AC and have noticed that it took forever to cool the truck down. I just thought it was because I was in an extended cab truck and not a regular cab (like my previous trucks). This afternoon on my way home I had my hand in front of the air vents. I noticed that it would alternate between super cold and just cool. Is that a sign of low freon or a compressor or what?
Originally Posted by Shane1
Prolly low freon....is it still under warranty?
Originally Posted by BtownFord
yes but i hate to spend 2 hours to get a free can of freon when i could just buy one for a few bucks
heat
hits...it's not far off!Shane
It could be just enough refrigerant in the system to allow the compressor to cycle but if your low then it means you have a leak. Take it back to the dealer to have them recharge it and add dye to check for leaks.
And how hot was it outside?
Originally Posted by Quintin
Where'd you have the A/C set? Where was the temp **** at, what fan speed was it on, and what setting (max A/C or outside air)?
had it on max AC
and had the fan speed at wide open although i did alternate a little between fan speeds. But it alternated at all speeds as well
It was in the mid 80's i would say
My Supercab's AC works alittle better than my reg cab did...both 2005's. I was convinced that I was low on refrigerant...took it to the dealer, and they said it was fine. After awhile, I still wasn't satisfied so I went out and bought one of those canisters of R-12 with the guage on it. According to the guage my AC was fully charged and didn't need any added to it.
Now the Supercab I drive seems to cool slightly better, but it still feels pretty inadequate.:o The only good thing is that here in Michigan, I only need to use the AC for about 3 or 4 months out of the year.
