Question about front brakes
Since I haven't had my rims off my truck, I don't know right off hand. Do the new F150s (2004+) use a hat style brake rotor on a separate hub or is the hub integrated into the rotor like nearly every other Ford? Also if it is integrated, are the bearings replaceable?
The two wheel drive trucks have the rotor and hub bearing integrated in one complete, sealed assembly. The rotor is retained to the spindle with a single 36mm nut. The bearing is not serviceable seperately, and it doesn't need to be cleaned/packed like the older two wheel drive trucks do.
Originally Posted by -TXF150-
Quintin, the 36mm nut says "DO NOT RE-USE" can it be re-used, or do I need to buy 2 new ones when I turn my rotors??
Part number for the nuts is 6L3Z-3C294-AA. Torque to 295 ft/lbs, rotate the rotor counter clockwise five times and recheck your torque.
Originally Posted by jjmIII
What about the 4x4?? Are they hard to turn off the truck?? Disk rears??
i think ford made a huge mistake by not making the 2wd rotor and hub assembly just like the 4wd. if fomoco is trying to keep costs down wouldn't it stand to reason that 1 type of rotor hub assembly for all f150's is cheaper than 2 separate assemblies for 2wd and 4wd?
