Highflow cats?
Highflow cats?
Got my Magnaflow exhaust installed the other day and the guy that installed it said I should also look into replacing the stock cats if I am wanting to get more power out of the 4.6L. For those that have replaced the stock cats, what brand and model # did you use? Would I throw any codes if I was to replace them. So far all I have done to the exhaust is have a Magnaflow 12158 muffler installed (14" 2.5"/ dual 2.5" out) side exit. Thanks for the help.
Andrew
Andrew
Andrew
Andrew
http://www.ninosport.com/Metal-Cat-C...&category=1074
http://cgi.ebay.com/ebaymotors/Metal...QQcmdZViewItem
http://www.troyerperformance.com/cgi...c%20Converters
Are you going to notice a 5hp improvement at peak in a 5000lb+ truck.. doubt it.
i was thinking about the high flow cats myself with a true dual setup. muffler shop guy told me i was crazy if i wanted to do that to a near $ 40,000 truck. he said if they were off on anything they did i would have problems that i would have problems with check engine lights that they wouldnt be able to fix without going back to what i currently have. he refuses to do the job.
theres got to be some more advice on this issue out there. lets get some more replies to this thread guys.
thanks
thanks
