Question for audio guys! "lumador"
Hey everyone... i posted this over in the other section but didnt get too many responses.
I just ordered the supercrew box duals 10s with the kicker cvrs
I also ordered the 6.5 polk mmc6500 momos speakers for the front.
I just need an amp or amps now! What should i get? Should i get a 4channel and bridge it? or what
should i go with two amps? i want to spend 300 max probably. What do you suggest? I was thinking one of these?
http://search.ebay.com/search/search...tSearch=Search
http://cgi.ebay.com/Alpine-MRP-F450-...QQcmdZViewItem
Or should i go with two? one for speakers and one for subs
Well.
Depending on what you are using the amp for. If you are using the amp on the subs and 6 1/2"s you would be better off with 2 seperate amps. Your subs will not require a super clean sound since it will only be used for low tones.The 6 1/2"s the cleaner power will be more effective.
May I suggest this amp for your subs.Just run them bridged. I have this in my car with 12" rockfords.Best bang for your buck. Plus its a class D which means less draw from your trucks power supply.Copy/paste link.....
http://cgi.ebay.com/KENWOOD-KAC-7203...QQcmdZViewItem
As far as the 6 1/2" I would save a few extra and get a decent 4 channel,like a clairion. The best sound on mids and highs I always have used clairion or JBL. And they are not outragous in price.... Just my 2 cents.
I would definitely go with a two amp set-up. You can go with a 4ch amp and bridge the front and rear channels to give your fronts more power. Or you can just get a basic 2ch amp to power them as well. It really depends on the power requirements for those polk speakers and your budget.
As for your subs, same thing applies. Find a mono block amp that puts out enough power at the right impendance(1, 2, 4 ohms) and that also fits your budget.
Lumadar was sent to timeout.
