Where to find a 4mm combo wrench???
Old Mar 10, 2007 | 06:57 PM
Monstermile's Avatar
Just installed a new set of headlights and they are probably going to need adjusting. Looked through all of my tools and all I had was a long 4mm socket. So I stopped by Sears and the smallest combo wrench they carry is 6mm. Any idea where to get one outside of probably Snap-on or one of those other expensive companies??
Old Mar 10, 2007 | 07:20 PM
PHS79's Avatar
Instead of using a 4mm wrench I just used a 4mm socket and a pair of channel locks. I tried to use the socket with a low clearance rachet but it didn't fit, so I had to either use the channel locks or vise grip to grab hold of the socket.
Old Mar 10, 2007 | 07:25 PM
RamSS/T's Avatar
Craftsman has a set of little wrenchs called ignition wrenchs...they are like $20 for a set of 10 at sears (you can get them a lot cheaper on ebay.) The metric set has 4mm wrench in it (the set has a 4, 4.5, 5, 5.5, and 6 THRU 11MM in it.) I have both the metric and SAE set and use them a lot more than I though I would.
Old Mar 10, 2007 | 07:37 PM
PHS79: Thought about that but there isn't enough clearance to get the socket on the stud.
RamSS/T: They guy at Sears pointed those out but said they don't go down that small.
I just checked Lowes, Home Depot, Advance, and Auto Zone and none carry a 4mm. Guess I'll figure another way to do it without stripping the head.
Old Mar 10, 2007 | 07:41 PM
RamSS/T's Avatar
Well he didnt know what he was talking about:
http://cgi.ebay.com/ebaymotors/CRAFT...spagenameZWDVW
I have that set and I can tell you there is a 4mm wrench in there....the set is in a little plastic bag.
Old Mar 10, 2007 | 07:45 PM
Just use an adjustable wrench.
Old Mar 10, 2007 | 10:09 PM
mwheue's Avatar
X2 I have the same set with a 4mm socket in it and they work fine.
Old Mar 11, 2007 | 06:27 AM
snowboarder7710's Avatar
i have something similar to this....i got it from the snap on tool truck that comes to my work.......
http://buy1.snapon.com/catalog/item....re&dir=catalog
