Question about changing front shocks
Old Mar 10, 2007 | 01:56 PM
GB150's Avatar
I know I'll need a spring compressor to get the springs off but will I need to undo the front tie rod to remove the front shocks or can I just unbolt them and remove them? I searched and din't see where anyone has ever mentioned this, but I read in an online article where it said it was necessary. Or at least that was the way they did it in the article. Thanks.
Old Mar 10, 2007 | 02:23 PM
hmfic's Avatar
Yes, you will have to remove the tie-rod end, which should take all of 2 minutes or less to do. You can get away without popping the upper ball joint loose but you have a greather risk of tearing the cv boot due to not being able to swing it further out of the way. If you have putting a leveling kit of some sort in you definitly want to brake the hub away from the Upper control arm.
Old Mar 10, 2007 | 02:37 PM
GB150's Avatar
I'm not using a spacer. I'm going the other direction and lowering the truck tomorrow. I'm using the McGaughy's 2/4 drop. It's lowering coils in the fron and leaf springs in the rear. I'm also installing Bilstein shocks while I will have it apart. So I should be able to unbolt the tie rod end? Or will I need to use a "pickle fork" to break it loose?
