ATTN: Bilstein 5100 Series Owners
I have a few questions. The front shocks mount to the LCAs the same exact way as stock, correct? I'm going to be putting them on my Rize equipped truck and need to know if it'll work with Rize's strut extension. I already ordered them overnight so I'll be getting them tomorrow but I'll sleep better knowing that they'll work. If anyone could post a picture of them down by the LCA or off the truck that'd be AMAZING! I couldn't find any pictures of them for a F-150 so help me out!!
One last thing . . I'm trying to understand how the lift is achieved. The placement of the coil on the strut achieves the lift, correct? . . to get more lift the spring needs to be compressed more, correct? I hope these will work thats all I'm going to say and if not, I'll have a brand new set for sale.
Originally Posted by -TXF150-
They work basicly like the fabtech 6" lift struts, except they are 2" of lift..
I don't doubt I'll be able to use them. I'm just wondering about if they'll work cranked the full two inches. What do you think?
how much were they thump?? so they give 2 inches of lift?
im thinking ill be doing this too...i need those 2 inches with my 38's.
They were about $400 shipped overnight. .
TX150
The strut attaches in the middle of the strut extension and the top of the extension butts up to the 'coil ring' I don't think it'll be a problem, just harder to install if anything but thats it. What do you think?
TX150
TX150
TX150
Thump, your lift is achieved from the dropped front crossmember and the shock makes up the difference compaired to the stock shock, that is if you are using your stock coil which has to have a shock that will allow for the stock springs compression/extension lengths. As for the strut extension, they should work fine and are all universal. My 5100's are adjustable from 6 to 8 inches, however, i have a 2 1/2" strut extension with my struts set to 6", which is how i get the odd rake/stance of my truck, which sits higher in the front. Which is all temporary until i get my 38s, which at that time ill crank my shocks up to the full 8" giving me 10 1/2" of total lift in the front. And ill have to go to 8" blocks in the rear.
that seems like a lot of block....Are there any shocks for the front that are adjustable from inside the cab? via air control?
