Survey of 2.5" Leveling kits
Old May 9, 2007 | 04:24 PM
  #46
jbergb5's Avatar
1. EZ Lift - Ebay $90. Can't find their presence anywhere on the internet now
2. 60k
3. BFG All Terrain KO - 285/65/18
4. No Problems at all. Had to do minor trim on splash guards with larger tires
Closeup:
Lifted before adding BFG's:
Old May 9, 2007 | 04:51 PM
  #47
dbhost's Avatar
I am being a dee dee dee today.....
Old May 9, 2007 | 04:55 PM
  #48
dbhost's Avatar
Originally Posted by titansu
QFT!
With 33s or 35s (or the metric equivalent) installed, has there been any issues of towing or loading the bed that caused the rear tires to rub on the rear walls? I suppose the AAL or AS Rear Lift would prevent this, but it seems like you’d return to the original issue... slight rake (just w/ larger tires).
With my rear axle solidly planted on the bump stops, I can honestly say my 285s had PLENTY of room all the way around them, no rubbing.
Old May 9, 2007 | 06:04 PM
  #49
Piccolo's Avatar
1. Autospring 2.5" New design
2. ~5000 miles
3. Stock 255/70tr17 on the stock wheels.
4. No problems yet
Old May 9, 2007 | 10:07 PM
  #50
2 1/2" Daystar on for almost 2 yrs. with no problems. Putting 315x70x17 BFG's back on tommorrow. Hope not too much rubbing with new wheels.
Old May 10, 2007 | 09:19 AM
  #51
CJ-F150's Avatar
Originally Posted by CJ-F150
CCMOffroad 2" Leveling kit
100 miles
Stock -planning on 325/60 18 Hankook Dynapro MT's or Toyo AT once problems are clear
Problems- Popping during sharp turns. Getting it checked out today hopefully. Any ideas on whats causing the popping would be great help. I can feel it when it happens, but haven't pinpointed the issue yet.!
Help!!!
Lift kit was fine, One of the bolts in my lower control arm didn't get tightened up good enough after my alignment and the alignment got way off. The bolt was tight enough that it wouldn't slide easily but during hard turns it would move a little which is what caused the sound. Took it to the shop last night and had it realigned. Everything is good now. I choose the CCM kit because it has the offset, and it comes powder coated for $70 +$13 shipping. Install of the spacers and alignment set me back whatever it will cost to take my brother-in-law and sister out to dinner next weekend! Did I mention he is getting me 325/60 18 Toyos for $179 a tire? I may even have to buy him a few drinks!
Old May 10, 2007 | 09:20 AM
  #52
CJ-F150's Avatar
Those are Open Country ATs by the way...
Old May 10, 2007 | 12:22 PM
  #53
hazelbalz's Avatar
1. Revtek 2" then switched to AS 2.5"
2. 2yrs on revtek/ 150 miles on AS
3. 285/70-17 BFG MT's
4. No problems at all
Old May 10, 2007 | 12:26 PM
  #54
chumFX4's Avatar
Daystar 2.5"
12,000 mi
325/60/18 Hankook MT
Trouble free!
$250 for kit, installation, and alignment
Minor trimming required.
Old May 10, 2007 | 05:05 PM
  #55
Tylus's Avatar
1. AS 2.5"
2. on at 10,500 miles, now at 13,100 miles
3. oem 18"
4. none...love the stance
Old May 17, 2007 | 12:26 PM
  #56
WhiteGTSofDeath's Avatar
1. AS
2. A little more than 20,000
3. 315/70/17
4. None Yet
Old May 19, 2007 | 06:15 PM
  #57
xlint1's Avatar
04 XLT 2WD Supercab. NCD 2 1/2" off Ebay. Just removed them today. Made the front end sit higher than rear, and I never liked how close the upper control arm sits to the coil. It would contact the coil when jacked up, so a good pothole????? Truck rides better without the kit. I'm gonna try the rear lowering set up now.
Old May 19, 2007 | 06:45 PM
  #58
supachargd2k5's Avatar
1. Autospring 2.5
2. 5000 Miles
3. 275/55/20 Pirellis
4. None
I paid $82 and di the install wiht a buddy
Old May 19, 2007 | 07:54 PM
  #59
Tylus's Avatar
how did the kit affect your ride? all your doing is raising the front of the truck...
unless your kit was one of those that required a coil-over disassembly?
Old May 20, 2007 | 11:46 AM
  #60
Foozeball67's Avatar
2" Tuff Country kit
New 275 60 20's Toyo A/T's
Paid $125
Got about 200 miles on them (50 in the mud)
Rides great, no problems
