What To Do??~$800
Old Feb 20, 2007 | 10:59 PM
  #46
brypink2's Avatar
Originally Posted by patshea098
i see your running 2 of those amps.....one for each sub? or one for subs....1 for components im guessing logically?
basically what im tyring to figure out is....
what amp to go with....to have all the power i need with my AudioMobiles...but if i decide to switch to some newer sbus like the MAGS or IDMAXS to have plenty of power for them.
so what do you say? my AudioMobiles are **SVC 4's...so i need a amp that runs 1 channel at 2 Ohms**
also if i were to buy from RE what model should i go with to get good SQL??
Yep, one 9.0 on the subs (2ohm version) and one on the comps (4ohm version).
I answered your amp ??? in your "what amp?" thread.
https://www.f150online.com/forums/sh...16#post2492316
The MAGs are only 2ohm...so whatever 2ohm amp you get you'll be fine (depending on power). Other subs...like ID can usually be bought either 2 or 4 ohm.
Yep, I agree with 04yellowf150...if I were to get a RE (but I wouldn't)...it would be the XXX. They sold out and are ridiculously priced now. Also, I know someone that sells them new.
EDIT: Go check out my thread over in the amplifier forums.
Old Feb 21, 2007 | 12:31 AM
  #47
04yellowf150's Avatar
ok how about FI
fi was created by the former owner of RE audio.
check the BL series subs. FI has the same if not better quality then re with ALOT cheaper prices
