False Starts
Old Feb 8, 2007 | 07:28 PM
06FX4SuperCab's Avatar
Exclamation False Starts
So I've had my truck for a month and a half now and I'd say about once or twice a week it has what I'd call a "false start", acts like its gonna turn over and then nothin. After the first time it happened I just figured I wasn't turnin the key all the way so since then I've made sure that I do, but it has still happened. Has anyone else had this problem and how serious is it?
Old Feb 8, 2007 | 07:30 PM
06FX4's Avatar
mine did that a couple times when i first got it, i took it to the dealer and they reflashed the PCM and it hasnt done it since!
Old Feb 8, 2007 | 07:31 PM
hllon4whls's Avatar
If its turning over, but doesnt catch and you let go of the key in the time frame of when it would have normally started, as long as it does start its ok IMO.
Mine every now and then will turn over and I let go of the key in aticipation of it starting. If this happens, I have to turn it for a few seconds and it catches. I dont think this is a problem.
Old Feb 8, 2007 | 07:36 PM
a n t h o n y's Avatar
Banned
FYI a TSB is out there for "something" like this
TSB 06-19-14 NO CRANK / STARTER TERMINAL FATIGUE
ISSUE:
Some vehicles may exhibit a no crank condition due to an open circuit in the starter relay to starter motor circuit at the starter motor connection.
Old Feb 8, 2007 | 07:41 PM
FX4_Guy's Avatar
ISSUE:
Badass...gotta add this to my list the dealer needs to check out.
Old Feb 8, 2007 | 08:03 PM
yea I mean it doesn't seem like a big deal because it starts right up after the second try just kinda annoying for a brand new truck to be doin somethin like that. Butttt it's under warranty so I guess I'll let the dealer figure it out. Thanks for the input guys glad i'm not the only one that's had this problem.
Old Feb 9, 2007 | 09:33 AM
FX4_Guy's Avatar
My 2003 mustang gt did the same thing for about 2 - 3 years before I traded it off. It always did it after it had been turned off for about 3- 15 minutes or so. Basically the only time it would do it was when I stopped for gas or a quick trip inside the grocery store.
Old Feb 9, 2007 | 11:27 AM
Inline6's Avatar
You might try waiting a second or two after turning the key to the run position before you move it to start. I read in one of the forums that no start may be due to the ecm waiting on input from different sources, such as the fuel pump, before starting.
Old Feb 9, 2007 | 12:29 PM
tardman91's Avatar
Mine used to do it, and I've complained about it a few times and had my PCM re-flashed. I told my dealer about the TSB last time I was there. All they did was re-flash the PCM again. It's been fine for a few weeks now.
Old Feb 9, 2007 | 01:20 PM
TysonsLariat's Avatar
Bingo! Sometimes the electronics do not all respond instantaneously giving false readings.
Old Feb 9, 2007 | 02:14 PM
Hmm interesting..I'll give it a shot over the next couple weeks see if it does it again.
Old Feb 9, 2007 | 03:39 PM
Stragum's Avatar
Man, don't tell me this is starting on some 06's now. Sheesh!
Here's the thread that I have had running for some time now, it may offer you some advise on what to do.
Good luck!
https://www.f150online.com/forums/sh...hlight=Stragum
