blue tooth hands free ?
Old Feb 7, 2007 | 01:32 AM
4 da boat's Avatar
How good does the "Blue Tooth" work form MOSS ? And will it work with an after market head unit ? Is there any other cab mounted blue tooth systems out there ?
http://www.f150store.com/SiteGraphic...09Complete.pdf
Old Feb 7, 2007 | 01:58 PM
sysman_rick's Avatar
Try Brandmotion.com . They have a rail mounted unit that plugs into the stock sound system.
Old Feb 7, 2007 | 03:04 PM
goldmember's Avatar
I'm putting a Parrot CK3100 in my truck. Just waiting on the adapter. I had this unit in my tacoma and it worked great. The adapter is plug and play to the stereo. No wires to cut. A call comes in it mutes your stereo and you listen over the speakers. there's a microphone you mount up on the a-pillar or visor that you talk into it. Real nice unit.
www.parrotkits.com
Old Feb 7, 2007 | 10:57 PM
4 da boat's Avatar
Thanks guys.. I like the Brandmotion one but I don't have the "rail port " system I think I will go with the MoSS one
Old Feb 8, 2007 | 08:15 AM
goldmember's Avatar
The moss one looks very close to how the Parott one works. I'd check to see if it syncs up with your phonbook. The parott kit does and this is a nice feature. That way you don't have to fiddle with your phone to make a call.
Here's the unit installed in my tacoma. I'm just waiting for the ford harness to come in and it's plug and play as well like the Moss kit
Old Feb 12, 2007 | 08:25 PM
brianc's Avatar
I put my parrott CK3100 in last night. I've got to say it's a great little unit. I ordered from parrottkits.com, and the wiring harness made the install a breeze. Well worth the money, imho.
I've got audiophile, sirius, and the mp3 6-disc, and this kit works with all of that.
Now I think my next thing I buy for my truck will be a dust rag. It doesn't look that bad in person, really.
Old Feb 12, 2007 | 08:46 PM
goldmember's Avatar
Cool! Glad to see the harness is a breeze. My harness just came in so I should be installed it soon. I'm trying to hold off until Ipod unit comes in too. Thanks for the idea on mounting. I might remove my cigarette lighter and have the wire come through that hole and have the unit cover the hole. Probably going to run my microphone up the a-pillar like I had my tacoma as well.
Is there a lot of room behind the factory radio for all the wiring? It was a very tight fit with the tacoma.
Thanks for the pics!
Old Feb 12, 2007 | 09:22 PM
brianc's Avatar
Yeah, there is a ton of room below the radio and above the pullout cupholders. (I've got the 40-20-40 seat -- I'm guessing it's the ashtray for those with the floor shifter.) I just stuck the blue box to the top of the cupholder unit with some double sided sticky tape.
I wasn't sure about the placement of the unit, but I wanted it easy to see and I couldn't find a better place. The microphone pickup is good where I installed it. I'm sure up by the visors would be even better.
Old Feb 12, 2007 | 09:25 PM
goldmember's Avatar
Excellent! Glad to know there's room. I may end up mounting like you as well. I won't know till I start poking around and hopefully not breaking anything.
Old Feb 12, 2007 | 09:27 PM
04 RED LARIAT's Avatar
Old Feb 20, 2007 | 08:54 PM
goldmember's Avatar
Just and update. I finally installed my Parrot CK3100. Very happy with the results seeing that it works just like it did in my previous truck.
Here it is completed. I don't use my cigarette lighter at all and if I need a 12v outlet I still have another one.
I'll just post links for the rest of the pictures so I don't eat up bandwith.
I only velcroed the unit in place. I'm not into drilling my dash even though the piece is easily replaced.
http://www.fototime.com/68C0148ED272EE3/standard.jpg
Disassembly.
http://www.fototime.com/B75B811E64F9333/standard.jpg
Wiring for the bluetooth (there's a lot of it.)
http://www.fototime.com/85A4AA0BDBC0D32/standard.jpg
Test fitting the unit.
http://www.fototime.com/E8274C75390DC63/standard.jpg
Radio's out. Seeing what I have to work with.
http://www.fototime.com/524E3CE2E80B9F8/standard.jpg
Plugging the Parrot harness into the factory harness.
http://www.fototime.com/BF9C3A970AC34A5/standard.jpg
Ran a hanger to snake the microphone wire under the dash.
http://www.fototime.com/7C9BD7D5D48B0EE/standard.jpg
http://www.fototime.com/BFFFFF1474DA988/standard.jpg
A-pillar trim removed to run the speaker wire up. I just tapped in a few places to hold it there.
http://www.fototime.com/B950CC2B0BB1B1B/standard.jpg
Taming the wire harness.
http://www.fototime.com/11635C81A327623/standard.jpg
Nighttime picture.
http://www.fototime.com/9EF517B66CC3A8E/standard.jpg
Radio readout during call.
http://www.fototime.com/76EBAB59192A6AA/standard.jpg
I forgot to take a picture of a-pillar reinstalled but it looks like this.
http://www.fototime.com/DDF41562F283F4A/standard.jpg
Old Feb 20, 2007 | 11:36 PM
efiguero's Avatar
Nice pics!
Old Feb 21, 2007 | 08:28 AM
goldmember's Avatar
Thanks! I typically take a ton of pictures while doing an install on my truck or quad.
