Terminal understeer
Terminal understeer
thanks ford, now I have to buy a rear sway bar
I don't mind the understeer when I'm going 90 but come on a rear wheel drive truck shouldn't feel like a FWD car on ice when cornering
Jeez - anything will understeer on ice
. With the forward weight bias and lack of traction, it should be expected, no?Too much rear bar, and you'll be blessed with terminal oversteer
Cheers
Bubba
Originally Posted by MGDfan
Hi.
Cheers
Bubba
Cheers
Bubba
I think you're going to find that a rear sway bar will do very little to help a front engine / transmission, rear wheel drive pickup truck do much more than understeer on glare ice. There's just too much weight on the front wheels and not enough on the rears. Remember though, as Stirling Moss once said, "Understeer leads to very stable pile ups." I think what you experienced was Mother Nature and Father Physics double teaming you.
this isn't the first time I've had the under steer issues under 50mph on dry, wet, or icy pavement.
Hi.
I know - it's gotta be the bazillion pounds of sound deadener you added. That, coupled with the drop, peckered you chassis dynamics.
Or, it could be the FartMaster 50. Try a Super 40, mebbie? Heard they corner better
These trucks ain't sportscars or autocrossers - not without a LOT of chassis work. Mine pushes like a pig too.
Cheers!
Bubba
hey styx, did you ever weld (tack) the nuts and bolts to the frame from the lower control arms after you dropped it?
i thought i had a bad push one day in the rain, and the next day it happened dry. truck went into the corner at 35 and decided to start turning halfway through. come to find out the alignment guys didn't tighten the bolts to the lower arms and they loosened up, when i jacked up the front end, i could push the tire in and out, pretty bad.
ouch. I know they arnt tacked... never thought to have them tacked. I am dropping the front end another inch after I buy the roush shocks... that along with new front and rear sways should take care of that pesky body roll
since I added the rear sway bar and rear traction bars I have a lot of oversteer. I had to back my traction bars off a tad to balance the handling. Now with the new wheels and tires I put on 305/40/22's the truck really does handle like a sports car.
