Cupholder removal
First you'll need to remove the radio/heater trim. Pop open the cupholders. Insert finger on far edges under the trim plate and PULL straight out. It takes some force. After the trim is off, there are two bolts holding the cup holder in, remove those and slide it out.
Any reason you're taking it out?
This sounds insane:
The temp here in Germany hit the mid 20's last week, My cupholder had to be pried out with my ID card. The weather hits 40 degrees and it works fine.
i looked at the track, the rails and there is ALOT of grease on the rails. Hopefully cleaning the rails and using anothe lube will stop it from sticking.
trust me i'm not
trust me i'm not
Originally Posted by JurassicBob
scorpio333, where'd you get your headlights?
Maybe this spring I'll upgrade.
I bought my HD lights from this guys his name is Ed at parts@y2kford.com. I got my head lights and my tail lights cheaper than any prices I had seen on Ebay for OEM HD ford lights. Give him a holler. FYI, I hope I did not break any rules by posting the e-mail address, sorry if I did.
