cheap back up camera- VR3 wireless camera?? Nah or yah ?
I just got bored and surfing on ebay and figured to try find me cheap back up camera since i dont need to spend $400 or over for that.
Then i found this one, sounds interested, its VR3 wireless backup camera... any one has one of this ?
What do you think?? feedback?
Under $100 from ebay.
copied/pasted:
Wireless Back-Up Camera System with Color LCD Monitor allows you to see what is behind you before you back up
Comes complete with everything you need to install
Avoid accidents and injuries in your Car, Van, SUV, RV, or delivery vehicle
Camera mounts to your existing license plate holder and provides 110 degrees of horizontal camera viewing and 80 degrees vertical camera viewing (measured diagonally)
2.5" color monitor mounts to your dash or visor
For use with 12V DC electrical systems
Installation is easy with the elimination of wires
Help is available by calling the number provided
Easy to read, bilingual (English/Spanish) installation manual
copied/pasted:
Dunno about that one. I tried a wireless in my motorhome, ended up putting in wire...
still, may be worth a shot.
As to 400 bucks for a camera system, no you can do it for about 100 bucks if you have an aftermarket single din system.
That's monitor, cable and camera.
Monitor is pull out 7 inch screen.
I used a system like that for a year, before putting in my double din JVC monitor/MP3/DVD/SD etc.
Chris
Chris
Ha, i dont need fancy radio system since i m deaf
hehe...thats main reason why i m asking for cheap under 100...
I found some info after search, they seem didnt like it.. so i deicded not to buy VR3 wireless.
Maybe i ll try find me under $250 then...
I ll contuning do some search for more info..
Unless if you got good suggest brands, please reply..
Thanks!
YOMAN!
hehe...thats main reason why i m asking for cheap under 100...I found some info after search, they seem didnt like it.. so i deicded not to buy VR3 wireless.
Thanks!
YOMAN!
Vr3
I recently installed the vr3. I used this one because I wanted a 2nd camera in my 2 horse trailer and didn't want to have an rca cable running to the trailer. What I found is the truck mounted camera gives a slighty blurry picture(mtd on plate). The one in the trailer is mounted up next to the roof
(7'-0") and that picture is very clear. VR3 says the reason is the high camera has no real metal to block the signal like all the metal blocking the signal from the lower camera. It works for me because I only use the plate camera when I back up to hitch up but it's nice having the trailer camera to make sure the horse is ok.
Got mine at WalMart for $98 and change. The camera attaches to your tag bolts and is wired to the backup light wires and the wireless monitor plugs into your cigarette lighter or can be hard wired. Mine works fine and it is works good. Can hitch my travel trailer to my truck easily now. Got it to keep from running over children.
