CB wiring
Old Jan 26, 2007 | 09:55 AM
Silver05screw's Avatar
CB wiring
Those of you with CBs can you tell me how you wired yours up. Did you just tap into an existing power source or did you create a new one of the battery? Did you ground to just a bolt under the dash or did you go directly to the chassis? Thanks in advance for your input.
Old Jan 26, 2007 | 10:15 AM
mmotes's Avatar
I just tapped into the fuse box under the dash in the passenger floor board and used a connector on one of the fuse junctions w/out a fuse....
I used an inline fuse instead....and I grounded to the firewall under the driver's side.....
_motes
