How much rear lift on 8" rize???
Unless your truck was perfectly level stock, then it does not lift the rear 8 inches. I think it is a 5 inch block. Then they figured out an AAL was needed especially for the long bed trucks like mine. The front is where the 8 inches is measured.
Originally Posted by patshea098
ive never experience axle wrap...
The reason I ask is because, I'm thinking about next time i need tires... Getting some 37s and putting the bilstean adjustable shocks on with 2 inches of lift on them... giving me a total of 8" of lift in the front... So i need to bring the back up to about an inch higher than the front(I like the rake). I currently have a 3 inch block on top of the stock 2 inch block with a 1.5" - 2" add a leaf. So Ive got about 5 inches of lift on top of stock in the rear, and im going to need about 7 inches of lift in the rear after I put the Bilsteans in. Maybe I should take the add a leaf out and put in the 4" rancho leaf pack. What do you guys think?
Originally Posted by BestNTx
So the 5 inch block goes on top of the stock 2 inch block in the rear? and then you have an AAL? Do you guys experience any axle wrap?
Originally Posted by ThumperMX113
I've got the 5" block and a Deaver AAL, no axle wrap and sits perfectly level!!
Did you put the block on top of your factory or did you take the factory out? and how much lift did you net off of your deaver AAL?
