I have the worst luck.
Old Jan 24, 2007 | 07:00 PM
nuclearthreat54's Avatar
WTF! Ok, today I get my truck back from the dealership after them fixing my emergency brake system. It was free so its not that bad. But on the way to burger king, i tryed to squeeze between a car and the curb to get into the turn lane, and well i was doing good but then i went up onto the curb. Well, after burger king i started to drive home and 5 minutes into the drive i hear a squeaking noise, then my truck starts to vibrate BAD!! I think I bent a rim. Thats the only reason, unless ford did a crappy job with my rear end. If my rims are bent then I guess that gives me the go ahead on buying some Moto Metal 951's. Do they come in 18'" or just 20"?
Old Jan 24, 2007 | 07:02 PM
()smoke()'s Avatar
man, you must have hit that curb just right--or wrong!
good luck, hope it's nothing too bad
Old Jan 24, 2007 | 07:03 PM
TonkaTruck33's Avatar
yea they come in 18's too
Old Jan 24, 2007 | 07:21 PM
welfare wagon's Avatar
Burger King have it your way.
Sorry to hear about your misfourtune, if you need a wheel check ebay maybe you can get just one.
Old Jan 24, 2007 | 07:23 PM
Maybe that scary burger king guy is in the bed.
Old Jan 24, 2007 | 07:35 PM
a n t h o n y's Avatar
Banned
If you hit the front, you may have jacked up the alignment.
Old Jan 24, 2007 | 07:39 PM
KC-10 FE's Avatar
My question is how fast were you going when you hit that curb? No matter how shoddy the craftsmanship might be, bumping a curb will not throw you alignment out of whack & cause a bad vibration. If it did, no one in the world would have a car that drove correctly. I would say something else is wrong but who knows, it might have been the curb hit.
KC-10 FE out...
Old Jan 24, 2007 | 07:44 PM
KC-10 FE out...
Not even 5mph, i was creeping up casue it was rush hour and i was trying to squeeze by. I know its a crazy idea, but unless the dealership messed up big time, its the only thing that could explain it.
Old Jan 24, 2007 | 08:15 PM
KSpencer's Avatar
If you bent the rim, you would notice it right after getting up to speed the first thing, not 5 minutes into the drive. Bent rims do not squeak, but a dragging parking brake does. I'll bet that the stealership did not do the e-brake fix correctly. What you heard was the parking brake "breaking" again then binding up causing the vibration. Stuck parking brakes are notorious for causing a vibration. Check to see if the p-brake housing is warm to the touch after driving it. I'll bet that you will be visiting the dealer again for another "fix". Good luck.
Old Jan 24, 2007 | 08:26 PM
kd4crs's Avatar
Your parking brake may need to be readjusted. It sounds like it may be dragging, that will cause the vibrating you described.
Old Jan 24, 2007 | 08:32 PM
Budha05STX's Avatar
Unless you knocked a balancing weight off. But it sounds like the e brake still needs some work.
Old Jan 24, 2007 | 08:59 PM
captain morgan8's Avatar
I know how you feel man. Today I realized the inner sides of both my front tires are worn down pretty bad and I only have 5,000 miles on em. I have been waiting on the bumper I bought on ebay to get here for a month and both my rear wheels are starting to rust.
Old Jan 24, 2007 | 10:57 PM
ThumperMX113's Avatar
Sounds like the dealership messed something up, you wouldn't bend a wheel at 5 mph unless you were running about 5 psi. The stock wheels are pretty strong. I'd have them check out the E-Brake, it's probally sticking.
Old Jan 24, 2007 | 11:38 PM
Hash278's Avatar
Man he has the funniest face!!!!
