Engine squeaking
Old Jan 22, 2007 | 05:29 PM
98teal250's Avatar
Engine squeaking
Once and while when I start my truck it will squeak until it warms up. I took it too the dealership and it would not do it then. It does not happen every day, but it is starting to annoy me. Does anyone have a clue of what it could be? Thanks.
oh yeah i have a 04 supercrew 5.4
Chad
Old Jan 22, 2007 | 05:36 PM
BalogUK's Avatar
if it is really cold it will scream a bit- have you payed attention to the times it has squealed?
Old Jan 22, 2007 | 05:45 PM
98teal250's Avatar
it has only done it in the cold.
Old Jan 22, 2007 | 05:46 PM
anaheim's Avatar
My sons Ranger did that, only squeeled when initially starting it in the morning. Eventually got worse, ended up being a bad bearing in the alternator.
Old Jan 22, 2007 | 05:58 PM
98teal250's Avatar
hmmm...mine does not do it everyday, did yours sons?
Old Jan 22, 2007 | 06:04 PM
COFX4's Avatar
Mine does it on really cold mornings...Like when its less than 10-15 degrees....But it doesnt do it when it is warmer.....
Old Jan 22, 2007 | 06:12 PM
98teal250's Avatar
Yeah that is kind of like mine...but it will do it if it is about 25 or less
Old Jan 22, 2007 | 06:13 PM
sounds like an idler pulley, or compressor pulley if you typically start your truck with the a/c on
Old Jan 22, 2007 | 06:23 PM
Hawkpilot's Avatar
Mine was doing that when first started on cold mornings. I replaced the serpentine belt with a gatorback and no more squeal. It has only been a month or two, so I can't vouch for it being a long term fix.
Old Jan 22, 2007 | 06:27 PM
anaheim's Avatar
It started out random, maybe once/twice a week when it was cold out side, it would go away after about 5-10 seconds.... then as time went on, (about 2-3 months) did it more and more, finally the squeal became constant.
Old Jan 22, 2007 | 06:28 PM
BalogUK's Avatar
its definitely the cold- as noted above- mine will scream around 10*F and lower. it will do it for about 5 seconds and will then run normal- im not too worried
to answer hawkpilot, even a gatorback will do it
Old Jan 22, 2007 | 06:37 PM
Msl747's Avatar
Same thing happened to my Ranger, turned out to a bad bearing in the idler pulley. Could just be your serpentine belt...
Old Jan 22, 2007 | 06:39 PM
98teal250's Avatar
Thanks guys - i have the edge so I was thinking about a gatorback belt. If it continues i will have them check out the pulleys. Thanks!!!!!
Old Jan 23, 2007 | 10:58 PM
Riken's Avatar
the hamsters don't like the cold weather
Old Jan 23, 2007 | 11:18 PM
the4by4freek's Avatar
Dayco makes a belt that is exactly the same as the Goodyear belt. It is a Driverite. It is cross checked and the quality is excellent. Mine is due to be changed. It chirps a bit when cold and squeels at WOT with the Edge. About $40 for the belt.
