Having problems with horn sticking ON
Old Jan 18, 2007 | 10:50 PM
stylinf150's Avatar
Angry Having problems with horn sticking ON
About a week ago I was blowing my horn at a another car backing into traffic and it wouldn't go off. I figured the horn ring under the center piece in the steering wheel was stuck in so I hit it a few times and the horn stopped. I tried the horn again and it worked fine. Well the other day I went to blow my horn to a friend as I passed and the horn stuck again and the center piece acted the same so I hit it a couple times and it stopped blowing but when I went to hit it again it was dead. I looked in the fuse panel and sure enough it had blown the 20Amp fuse that it is on. I attempted to put another in but it popped it. Next I had my brother tap on the center horn piece to free it up and tried another and it went in fine. I was wondering if anyone on here has had this happen to them or if any of the ford techs have heard of it...I plan to take it in for a oil change in 2 weeks but I figured I would see if anyone else had an issue.
Any info would be a big help
thanks
Old Jan 20, 2007 | 02:51 PM
nothinbutaford's Avatar
The springs that hold the button up sit in plastic cups, the spring may be caught or slipped over the cup touching the metal.
Old Jan 20, 2007 | 04:21 PM
stylinf150's Avatar
thanks for the info..another odd thing about the horn is that if I dont use it for a week or so it seems as if it is hard to push the horn in..after the first time it seems a lot easier. I dont know if it is possible but could there be corosion in the assembly???? I am now affraid to use it unless it is a dire emergency due to the fact that it stuck again yesterday. My only hope is that it does it when I take it in for the oil change and they can fix it.
