Is there a way to make these wheels fit
Old Jan 11, 2007 | 10:20 AM
ffmueller81's Avatar
Here are the rims that I would love to get for my 2006 2wd STX
It is a manual 6 cyl if that makes a difference
http://www.fordracingparts.com/parts...tKeyField=8870
Summary:
20 x 10
backspacing: 7.125
It says they will only fit 4 wheel drive '04-'06 F-150's
I am assuming that they won't fit 2wd since the backspacing is so huge (7.125).
But, can I use spacers, level kit, anything so that I can get these rims to work???
Old Jan 11, 2007 | 10:41 AM
RjA150's Avatar
Must have something to do with the back spacing or the 10" width. I know for a fact that normal 4wd wheels bolt up fine on the 2wd's, I have 18" FX4 wheels on mine.
Old Jan 11, 2007 | 10:49 AM
Monkey-1's Avatar
X2!!
Old Jan 11, 2007 | 06:09 PM
05RedFX4's Avatar
the arm on the spindle where the tie rod bolts up might cause a problem, but the upper and lower a-arms are the same on 2wd and 4wd. Good luck finding them, the only place I could find was http://www.summitracing.com/ for $340 each
Old Jan 11, 2007 | 08:01 PM
GB150's Avatar
I like 'em
Old Jan 11, 2007 | 10:35 PM
wandell's Avatar
I don't know. The 22x9.5 Eagles on my Expy (same wheel used on F-150) have 6.7 inches of backspacing. My tire (305/45-22) is very close to my upper ball joint. In fact, when my wife recently had an accident (hit a deer) I could see a scrub mark where the tire hit the upper ball joint. My guess is that on 4x2's the tire would touch the upper ball joint.
Old Jan 11, 2007 | 10:37 PM
mlawdawg's Avatar
Tire rack has 'em with better backspacing and offset. Check it.
Old Jan 12, 2007 | 08:35 AM
edit: I found what you are talking about...
+44 offset. I am not sure if that is a typo because I thought they only came in one size???? Don't know though
The ones on ford racing would be +54 offset if my math is correct
Old Jan 12, 2007 | 08:36 AM
Do you think that spacers would be able to fix that??
Old Jan 12, 2007 | 09:00 AM
styxnpicks's Avatar
ya, my wheels stick out almost an inch more than those rims do
Old Jan 12, 2007 | 10:15 AM
azmidget91's Avatar
i love those wheels if they had a bit less backspacing so it had a lip and were 22's and chrome i would have probably gotten those
