Engine Fail Safe Mode and Edge????
Old Jan 10, 2007 | 01:34 AM
weazel's Avatar
Registered User
hey people, well i was out driving around and i was gonna do a 0-60 time, went to build up the rpms to launch the truck by power breaking a bit( around 2000 rpms). Then on my dash the screen displays "Engine Fail Safe Mode". My tuck started to miss fire like crazy, shut the truck off and back on then went away...
has any one had this problem or know what this is
Current mods are
Volant
Magnaflow exhaust
JBA headers
edge
can some one help me out, it has miss fired like 10 times on normal driving then goes away then it has go into "Engine Fail Safe Mode" twice...
Old Jan 10, 2007 | 07:44 AM
Marc Carpenter's Avatar
Current mods are
Volant
Magnaflow exhaust
JBA headers
edge
The only misfire I can relate to while under normal driving conditions is when I was doing an R&D in an experimental intake system. While cruising at normal highway speeds the engine would occasionally misfire. Truck went into failsafe limp mode and lost power. Read the code and truck was running very lean which caused the condition...I had had the intake on for over 500 miles before this occured...
Old Jan 10, 2007 | 12:31 PM
FX4_Guy's Avatar
When you powerbrake while in stock tune, does the engine misfire also? I'm thinking your pcm knows your doing the following:
1. In drive
2. The engine is reeving
3. The truck isn't going anywhere
so with the above going on, it probably thinks there is a problem somewhere and it is telling you about it.
Old Jan 10, 2007 | 12:48 PM
weazel's Avatar
Registered User
1. In drive
its in lvl 3 edge, do you recomend trying it on stock tune and see what happends?
Old Jan 10, 2007 | 12:53 PM
FX4_Guy's Avatar
I wouldn't recommend powerbraking at all but if you inclined to try powerbraking in stock tune, I'd be willing to bet it might to the same thing.
Old Jan 10, 2007 | 12:57 PM
06FX4's Avatar
i have power braked my truck befor with the stock tune and that didnt happen.
Old Jan 10, 2007 | 01:01 PM
the4by4freek's Avatar
I have power braked mine in lvl 2 before. No problems whatsoever.... except for the NASTY set of black marks and the tire smoke that filled the parking lot!
Old Jan 10, 2007 | 01:38 PM
weazel's Avatar
Registered User
so do you guys think there is somthing wrong with my trucks ecu?
Old Jan 11, 2007 | 04:08 PM
MADDAWG's Avatar
engine failsafe mode n edge
I have a 2004 screw with an edge on it. It has done this numerous times on me. Checked codes n got p2106 throttle actuator control system-forced limited power.It only did it on initial start n take off , turn truck off n restart it was fine. I went back in custom tunes n raised my idle rpm 200 rpm n haven't had any trouble since i've done this.I am running level 3 with custom settings ,this is the only problem i have had as of yet.I love the edge best bang for the buck you'll find. Hope this helps.
