who did their own system
Old Jan 4, 2007 | 05:46 PM
alex_pitts87's Avatar
Arrow who did their own system
i want to install some subwoofers my self is it pretty tough to do your self
i have done it before on others cars
and any idea where i could find a wiring diagram for the stock Head Unit
any tips would be much appreciated and thanks in advance
Old Jan 4, 2007 | 05:49 PM
Zaairman's Avatar
On a stock headunit, it's a PITA to install it. I'd leave the wiring behind the headunit to the pros.
Old Jan 4, 2007 | 06:30 PM
SAtownTX's Avatar
would it be a pita if i had the stock woofer?
Old Jan 4, 2007 | 06:37 PM
04procompLARIAT's Avatar
Its not that hard. I did everything all myself. Just take your time and it will be good to go. Crutchfield has really good installation instructions.
Old Jan 4, 2007 | 06:42 PM
top_sgt's Avatar
got my pioneer head unit, subwoofer and amp for crutcfields. got my wiring local. crutchfields has a lot of good info on their web site about the how-to. did the install myself,,,,, and it sounds wonderful. my 14 year old son says it sounds good too!!!!!!
Old Jan 4, 2007 | 06:45 PM
I did my own, if you need a specific diagram IM me on aol and i can send you the (pdf) file.
-Patrick
Old Jan 4, 2007 | 07:00 PM
SteveVFX4's Avatar
I bought a MTX amp with speaker level input and just tapped into the rear speaker wires running along the driver's door sill. I found the speaker wire colors by searching this forum. And I hooked my amp up to a 10" MTX sub in a supercrewsound.com box. I put the amp under my passenger seat. Pretty simple.
Old Jan 4, 2007 | 07:01 PM
jmt0645's Avatar
I did my own system, took all of 1 hour to do. The easiest way to run power wire BTW is to slip it threw the grommet on the firewall just behind the battery. here are some pics of my setup now although I'm changing it all out pretty soon.
My amp is in a custom hard wood box with 4 fans for cooling
2 12" jenson strike subs in bandpass box w/blue neon.
whole sytem including pioneer HU is 1500 watt.
Old Jan 4, 2007 | 07:03 PM
02SuperCrew4X's Avatar
I've done several HU's before in almost every car I've owned. When it comes to subs/amps I know HOW but I can never make them look right as far as the running of the wires, etc..
This is why I will do any head unit but leave the rest to the pros.
Old Jan 4, 2007 | 08:13 PM
Well if you run a sub to under to rear seat you can hide the wires along the kick panel and then run them through the holes in the carpet for the jack. The mount the amp over the holes and BAMN you see no wires at all. Very clean install.
Old Jan 4, 2007 | 08:15 PM
NHSP-06's Avatar
Just do it yourself. If this is your first time, it may seem overwhelming but it's actually really simple when it comes down to it. I've installed at least 20 FULL stereos and I always do all the work to my own vehicles' stereo. There are enough places online where you can get full instructions with diagrams to help you along the way. And if you cant figure it out, post your problem and somebody here will be able to help you.
Old Jan 4, 2007 | 09:49 PM
04yellowf150's Avatar
wiring is not hard. but whatever you do, do not cut the factory harness, at the shop i work at i have to correct the mess and its a pain, if your gonna do it do it right lol
if you want the color codes for the wires ill give them to you, but if ur in doubt get a professional
Old Jan 5, 2007 | 01:00 AM
RamSS/T's Avatar
I installed my system...nothing special: in-dash DVD...a digital sound processor...3 additional monitors...2 amps....2 10s...XM...components in the front doors and coaxials in the back doors. It did take a little longer than an hour though.
Old Jan 5, 2007 | 01:10 AM
bushtree's Avatar
If you have any specific questions just let me know, i install stereos all day long for work..
its really not that hard. just take your time and look at lots of pictures on these forums..
Old Jan 5, 2007 | 01:34 AM
Haha..I also installed a in dash TV, PAC steering wheel controls and DvD bypass, Sirius radio, 2 amps, component speakers in the front doors, aftermarket speakers in the rear, and a JL audio stealthbox. Its not hard at all...the hardest part is programming all the equilizer levels to make the system sound good. Take your time!!! And dont jury rig anything!!!
