Some useless info on the PATs system and keys
Originally Posted by whitecrystal1
My brake light wire is hooked up and it does kill it if pressed. Unless the ignition is in the run position switch first. Then it just goes out of remote start mode and goes to run mode so it can be driven. It's really the same thing as starting it like I did with the steel key with the help of the pats key.
I know I have to be missing something here. ?
Sorry to hijack your thread but I was trying to find out when Ford started using the PATS keys? I just purchased a 98 F150 and it doesnt seem to have one. I'm going to get remote start and need to know if I need something besides the kit.
Viper
The steel key didn't work by it's self I had to hold a pats key over it to make it work. It was a little shocking to me that the truck didn't cut out when I moved it away.
One thing that also tells me thinking about it more, is that if I or anyone of us has our truck running from the remote starter and a thief gets in the truck and breaks the ignition, he can drive off with it without any key
As long as it's not turned off it will run
Even if you "break the ignition" truck will cut off if brake pedal is pressed or if engine rpm's reaches 3 time idle speed...
Now if you can drive the truck and never hit the brake pedal and don't let the RPM's go over 1500, you're good to go....
Originally Posted by F150Truck'in
No, it don't work like that on OEM Ford and Power Code remote start systems if properly installed...
You are correct, WITH a Pats or Reg Steel key it will be drivable, BUT when most thieves "break the ignition" they don't put a key in (also wrong or blank key would just make it harder to break) and on OEM Ford and Power Code remote start systems (not sure about viper) the systems have a "Key In Sense" this tell the system brain if a key is present in the ignition and this condition must be met also to keep the truck running, now keep in mind this is what I was told by a Power Code installer... I needless to say have never tried it out.... but I do know for a fact it does have a Key In Sense wire as I installed my own system....
1, The remote starter times out, and at this point if the key is on it will continue to run, whether it be a steel key or a PATs key.
2, You push on the break pedal and it take the remote starter out and your running with the ignition in the run position.
Here is what I was thinking when I tested this , and this is a long shot
You don't need a PATs key once the truck is running, just the ignition to be in the run position and if your truck is running from the remote starter and a thief gets inside and breaks the ignition and is able to turn it to run, even without a key he can drive it away.
Sorry for all the ands and the long sentence and I know this would be a long shot, but it's possible
Oh, it would be driveable no question if the "Key In Sense" does kill the engine.. I have wondered about that myself..and can't test it out
You can check to see if the Viper System has a "Key In Sense" just put a key in the ignition, not turned on, just stick it in... close the door... then try to remote start... mine will not remote start if the brains senses a key in the ignition, meaning it has Key In Sense, this feature is also used to not let the starter motor ingage to prevent starter grind...
1, With a PATs key in the ignition (not turned, just pushed in there) It wouldn't start. Everything light up like it would if you truned the key to run but not start.
2, When I put my steel key in the ignition the same way it did start.
That tell me the "Key In Sense" is using the PATs to tell if it's in there.
Why I think this is, is because it's using the PATs for the PIT STOP function (or what ever it's called). So when you go the the 7-11 and get out leaving it run in the remote mode it doesn't try to restart it sensing the key like you said. It doesn't know if it's running or not, just that there is a key in the ignition and thinks it is.
OK, I just tested it and I do have it. But this is what the test reviled.
