EDGE custom tune
Old Dec 29, 2006 | 03:45 AM
ffemt000546's Avatar
EDGE custom tune
So I have had the edge for a few months now, and really have just been using the pre loaded lvl 3 setting, with GR changed and tire size changed. I was looking to see what other peoples settings or "custom" tunes were. I am happy but, I want to get more out of my truck. So go ahead and list them
Old Dec 29, 2006 | 09:36 AM
It has been done several times, so you may not get much response. You may want to do a search. Mine are as follows:
Level 3: 93 octane
Timing: +1.5 (This depends on your local fuel, so just listen for the pinging, if you have it, back off on the timing)
Shift Pressure: +12 on all shifts (a guy I work with has his at +18)
Shift RPM: 1-2= 5250 2-3= 5250 3-4= 4800
Normal Sfifts: No change
WOT Fuel: +1.5
Max RPM: 5650
Max speed: 110
of course i adjust for my tires and gears
Old Dec 29, 2006 | 10:15 PM
Thanks Bluejay I figured as much and thought there was a couple of threads on here but was scatter brained last night. Thanks for you setup
