Leveling Kit Poll
Old Dec 21, 2006 | 09:39 AM
extremeethan's Avatar
No one? Thumper, you say they are bad what was your expirence with them? All of my problems have been because of me and torn boots. My lower boot tore on a rock not because of the AS and both UCA boots tore because of the UCA hitting the spring which I guess could be blamed on the AS and the worn out one is just because dirt got in the torn boot.
Old Dec 21, 2006 | 09:41 AM
lift shocks are for a 2 to 2.5 inch lift it verys by truck and there is a set in the classifieds
Old Dec 27, 2006 | 10:54 PM
rdsii64's Avatar
Registered User
lift shocks
Originally Posted by dlongoria
Had a Daystar 2.5 put on by the dealer before I took delivery. Rode ok, but front end felt kinda floaty if that makes any sense. Spindle also hit the coilspring. Just pulled the Daystar off and put on Bilstein lift shocks. It is supposed to only lift 2inch, but truck sits at exact same height as it did with the 2.5inch Daystar. Ride is great (better than my wife's 05 Sequoia)and no rubbing/impact issues.
I am thinking about leveling my truck. would you recomend the lift shocks as apposed to a leveling kit.
Old Dec 28, 2006 | 12:15 AM
gmb87's Avatar
Had the 2.5 AS and the front and rear were perfect height until any weight was put in the bed then had a rear low issue. Also didn't like the severe angle of the upper ball joints. This also made the front end ride stiff. I removed and went to stock. If I do it again I will only go 1.5 inches, a slight nose down , but better then stock and weight in the bed will ride level.
Old Dec 28, 2006 | 01:19 PM
azfordby4's Avatar
I have over 15k on my 2.5" as and have no problems as of yet. One of the upper boots has a small tear from the install though. Still no problems.
Old Dec 28, 2006 | 02:28 PM
allright Ive got all me new ball joints in heavy duty greaseable lower and swaybar links and new UCA! now just to but them in and get an alligment
Old Dec 28, 2006 | 05:20 PM
AirborneRacer's Avatar
Bilstein 5100s, 2.25 lift in the front with about 5 miles on them. So far so good I got them installed today so I am still feeling them out but I like the new level stance and cant wait for some new wheels and tires
Old Dec 28, 2006 | 06:40 PM
HiVoltage14.4's Avatar
How much were the bilsteins? Down the road Id rather add shocks and drop the spacer. How is the ride?
And extreme how much did new ball joints and all that run you?
Old Dec 28, 2006 | 09:28 PM
BHibbs's Avatar
2 Inch Lift Autospring (1.5" spacer)
74,000 miles
No Problems, Ride's great,
Moderate Off-Roading
Best Mod I've done...
