HELP, disconnected line from unknow location
Old Dec 17, 2006 | 05:21 PM
fowlerjc's Avatar
I noticed a rubber line that has come disconnected today on my 2005 FX4. If you look at the rear axle, left of the rear differential there are 2 lines coming off the rear axle. The line that is pointing almost directly toward the rear bumber (the bigger of the two lines) is disconnected at one end and connected at the rear axle. I do not know if this is some sort of drain and has no place to be connected or if it does in fact have a connection. I have experienced no problems with my truck. Please let me know where it should be connected. Thank you in advance.
Old Dec 17, 2006 | 05:38 PM
Budha05STX's Avatar
Pics might help with identification.
Old Dec 17, 2006 | 05:42 PM
Tbird69's Avatar
That's the vent hose for the diff, don't worry about it.
Old Dec 17, 2006 | 05:44 PM
Marc Carpenter's Avatar
RELAX.... Its sounds like you are refering to the third member (rearend) vent tube. It attaches to the axle on one side of the third member and the other end is open to allow for venting...Only time you should worry about it is if it gets plugged up when your off road four wheeling.This can cause the axle seals to leak if the unit can not breath..
Old Dec 17, 2006 | 05:45 PM
JForestZ34's Avatar
Yeah that's the axle vent tube. If you look up righht above where that hose goes into the axle there should be some sort of clip vent thing on the underside of the pickup bed. The piece probably broke and that's why it's hanging.
James
fowlerjc's Avatar
where is the other end of the vent hose supposed to be connected...it cant just drag along the road as I drive?
Old Dec 17, 2006 | 05:51 PM
Tbird69's Avatar
It's not connected to anything, it just gets clipped to the frame.
Old Dec 17, 2006 | 06:05 PM
heres where mines connected to the axle
and here is how i reconnected it, after we broke the clip when we removed the bed.
And yah its a vent hose
-Patrick
Old Dec 17, 2006 | 06:53 PM
fowlerjc's Avatar
thanks guys for the prompt responses...yall have been alot of help...one last question, on patman03sprcrw's pics there is a metal piece on the tip of the vent hose...my hose doesn't have anything on the end of it...yall think this fell off as i was drive with the clip broke?
